928 Forum 1978-1995
Sponsored by: 928 Specialists
Need some help with my '85 - THANKS, FOUND THE BALL!
Old 08-09-2006, 01:38 PM
Denis_A_Couroux
Denis_A_Couroux's Avatar
Oups.... meant 1PM and 6PM....
Denis
928 S3 5.0L / 32V
Old 08-09-2006, 01:43 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Well since you already check the idle, here are a couple other things to check for.
It could be vacuum leak or the idle stabilizer is acting up. You can remove the idle stabilizer by taking the air filter and the MAF off. The stabilizer is located on the passanger side right under the last two intake runners.
To check for a vacuum leak, get a can of starter fluid and with short bursts, spray the engine while its running. If you find a location where the rpms go up, you can start looking for the vacuum leak in that area.
Old 08-09-2006, 01:54 PM
Denis_A_Couroux
IMO,
Thanks alot for the advice. Ether huh ? LOLLLL
I dont get the location of the stabilizer though.... Even with the air box *** completely off... I fail to imagine the location...
Denis
'85 928S3 5.0L / 32V
Old 08-09-2006, 02:22 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Originally Posted by Denis_A_Couroux
IMO,
Denis
I know its hard to imagine but it's there. Do a search on my name and the tread about the idle will have some pictures of what it looks like.
Quick Reply: Need some help with my '85 - THANKS, FOUND THE BALL!
