928 Forum 1978-1995
Sponsored by: 928 Specialists
Battery Cable routing question
Old Aug 7, 2006 | 07:44 PM
Joe F's Avatar
Joe F
Default Battery Cable routing question
Some of you miight remember, I am in the process of replacing my old battery cable with a larger diameter one on my '83 Euro 5sp.
I have managed to get all those plastic clamps off. The ones that hold the battery cable against the bottom of the car. Next question.... I can see the battery cable now goes inside some sort of protective covering and up around the back of the engine somewhere. The next time I find it, its in a red colored harness with some other wires coming out in the area of the alternator.
So what is the best way to remove the old cable? Is there a way to get it out of that harness? Should I just cut open the parts of the harness I can see, cut the end of the cable where it starts up the back of the engine and pull it out the front? How do I go about routing the new cable?
I hope these aren't REALLY dumb questions, but I seem to be at a loss at this point as to how to move this project forward. I cannot find anything helpful in either search or in the manuals. Any suggestions?
Old Aug 7, 2006 | 10:16 PM
Alan's Avatar
Alan
Electron Wrangler
The big wire goes to the starter - then a seperate smaller cable goes on to the alternator and up to the jump post in the engine bay... You should be able to fish to the starter - with the engine lower shield/tray off.
Alan
Old Aug 7, 2006 | 10:49 PM
Jerome Craig's Avatar
Jerome Craig
PM Sterling. He's done a battery cable upgrade.
