Manual trans swap: 2:20 LSD for a 2:73 or ? LSD anyone?
I am going to convert my 1986.5 928S track car to a manual. I have a 2:20 LSD manual trans from a 1986 928S and was hoping to swap with someone for a better geared trans for track duties.
Constantine
Constantine
Constantine
Constantine
At one of the local tracks I do reach the end of 4th gear in a long "drag strip" straight section and a shifting up buys questionable performance.
I can say that I shift about 1/3 less than my oil/air cooled 6 cylinder Porsche friends. The V8 torque means you don't have to shift, that is probably why Porsche picked the gear spacing - pretty much a 3 speed box for me on the track.
The best choice transaxle would be the GTS unit with an oil pump/cooler. Now if we could come up with a closer ratio "true" GTS 5 speed, that would help. But, there are no such gears available.
Good luck with your upgrade. You have a great track machine, any of the transaxles will improve it.
The '85 and newer transaxles were Borg Warner sourced and are said to have much better synchronizers and were beefier then the previous generation Porsche "crash boxes". Keep that in mind - you may find better longevity with a newer box. How about a GT transaxle?
'85+ syncro ring design patent is Borg Warner but I don't believe any parts are from them.
IIRR there could be one more obstacle in swaping pinion shaft between '85-86 and later boxes. I believe S4, GT or GTS gearbox has larger diameter front end in pinion shaft than earlier boxes. This means input shaft will also have to be changed when pinion changes. Which means also front gear in lay shaft needs to be changed as it's paired with input shaft. I'm sure it's possible to make swap work but it would be much simpler to get other box with shorter final drive. How to find extra '89 GT gearbox without buying entire car is other matter.
Originally Posted by Rich9928p
Given the fact that Porsche outsourced so many individual parts it is probably safe to say that the guts of the transaxles were not built in Zuffenhausen.
Originally Posted by Sterling
Correct the Pinion is larger in the 87 and later manual trans. I'm not interested in anthing with the smaller pinion. Constantine and I have already communicated.
In any case these gearboxes are real minefield if one just desides to swap parts between different types without really looking into it.
I have tried to ask Mr. Kibort a few times about what his car has for a trans and never got a reply.
Oh well,
Constantine
Oh well,
Constantine
Originally Posted by Richard S
Bah! Final drive means nothing....just ask Kibort
Rich
Rich
