Need a part
Need a part
I need the oil sender connector that is correct for a 93 GTS. 2 of the three wires at the connector are frayed. I have no clue if the sender can be disected.
Anybody have a harness to to hack?
Thanks!
Kevin
Thanks!
Kevin
Basic Sponsor
Kevin,
One of the wires on my GTS sender sheared at the rubber connector.
I was able to wittle away the rubber and expose enough wire to splice onto.
Worked ever since.
However I will check the 87 parts car to see if the sender is the same (3 wire) and if it got fried or not.
If its good its yours.
Worked ever since.
Thanks!
My oil pressure gauge started cutting in and out during the last hour of my 14 hr sprint back from Denver last week. I expect a loose connection.
Pls save me some looking time and advise where the oil sender switch is located
