Will these wheels fit?
I know this topic has been done to death, but I am still unclear on what exactly will and will not fit the 928. Can someone chime in on these sizes?
8 x 17 ET47
9.5 x 17 ET52
8 x 17 ET47
9.5 x 17 ET52
Gluteus Maximus
In the front that's less offset than is often recomended for handling reasons (65 is stock). But the outside edge should be in approx the same plane as my 8.5x18 ET52 - and they work, but just barely. Don't go with too wide a tire (I'd say 215 max), and they will probably work for you.
In the rear I have 10x18 ET52 on my '82, but the fenders have been flared (and they definately need it to work). So your 9.5" should work on the inside but may rub on the outside against your fender.
