What is this? Still trying to find the problem.
I'm still working on the funky 82 and have checked this part for vaccum and it holds it, it also has no vaccum when the car is running.
The next most important question is: WHAT IS IT and SHOULD IT BE CONNECTED TO SOMETHING?
My 87 has something similar and it has a hard vaccum line connected to it, but it's buried and I can't see where it goes.
The WSM hasn't provided any identification so far, can anyone help?
Rod
Rod
Administrator - "Tyson"
IIRC it has something to do with the gas fumes / Charcoal canister / air pump emissions system.
Whatever it’s called, my 81 no longer has one. If it's not causing a vacuum leak, I doubt it has anything to do with your issue.
Have you tried the break cleaner trick? That is how I found my massive air leak. Buy some good quality break clean (stuff that is mostly isopropyl alcohol - leaves no residue) - using the coffee stir size hose, spray everything that has any kind of seal. If your idle speed changes, you just found a vacuum leak.
Since you were spending all of the 4th weekend working on the car, should have brought it up here!
Rod,
It appears to be the EEC (evaporative emissions control) valve that controls the fuel vapors from the charcoal cannister and the fuel tank. Not sure about your 82 but they typically have a manifold vacuum line connected to the small port at the end and two larger ports connecting to the intake manifold and fuel tank. It appears that yours has been disabled.
Dennis
Dennis
Rod
Team Owner
Hi you may have found the vacuum leak try to find the hose that this vacuum diaphram connects to, if its plugged try reconnecting it, also look under the intake with a mirror on the passenge side, look for a thick metal tube that runs to the back of the engine then look for any hoses that may be touching this metal line, any hose that touches the line will probably be burned as this line has exhaust gasses running thru it, re[place any lines that are suspect
It sounds like Hacker has removed his completely with no ill effects. Of course he is selfishly not giving me his blower, which apparently solves the problem.
Rod
Inventor
That's the vapor recovery valve. It should have a small hose that goes to the ported vacuum on the back of the TB, by way of a thermo-valve installed on the heater hose connection at the rear of the right cylinder head.
While you're capping and plugging, remove the vacuum limiter (if still installed - the flying saucer shaped thing on the side of the TB), and plug with 3/4" and 5/8" heater hose blockoff caps. It can give you problems, and is not necessary.
Rod
Originally Posted by Scott M.
Rod;
As Ken points out... my lines to the vapor valve have always been a small red rubber hose.
Yank it!!
Yank it!!
Rod
Originally Posted by Dennis Wilson
Rod,
A vacuum leak, unless really big, would cause a high idle rather than stumbling. A low stumbling idle when cold, sounds more like a nonfunctioning AAV.
Dennis
Dennis
Rod
Rod,
The AAV is supposed to open and give more air during cold starts to prevent the stumbling. Did you plug the inlet and outlet lines?
Dennis
Dennis
Rod
