83 928S
83 928S
Hi guys,
Im a newbie here to rennlist. I have a 83 S that my dad and i are working on since early last year. Ill post pics asap. Any info/tricks about this car would greatly be appreciated.
thanx
Chasen
thanx
Chasen
well, we have done a full repaint, new carpet, dash re-appolstry, engine work done by DEVEK (thanx), and allot of parts that were falling apart or broken.
chasen
chasen
I'll try to post pics quickly, and you'll definetly see before and after differences.
Chasen
PS the re-appolstry was done by Rod, and looks great, and Paul is doing the pod.
Chasen
which of the.... Posts: 5,775... that I have made should I repeat ? your request is just a bit too broad and general for an answer. If there is a specific problem that you have then much help is available. You also can get some humor ?, attitude and harassment as well. Tell us more about your 928 project.
Jim,
Im woundering how to fit my front Turbo lookII wheels on my 928. The rears fit well, but the fronts i had to remove the center cap. Is there another way to use those wheels with the cap?
thanx
chasen
thanx
chasen
Does anyone know how to fix the A/C that blows hot air or do we need to replace it. If we need to replace it, which part need to be replaced? Any help would be great
thanx
chasen
thanx
chasen
1 Post
thanx
chasen
thanx
chasen
The center cap problem with the front axle dust cover interference can be fixed by removing the dust cover and triming them so they sit in farther just be sure that there is still clearance for the big axle nut.
