MOMO Steering Wheel Horn
Originally Posted by fbarnhill
Hi Brad,
When I did mine on the old 83, I had to bend the contact ring out so that it made contact with the pickup on the column. It took me a while to get it right and mine was almost broken where it curved out. I used it anyway and never had a problem with it for years. Are we going to see this thing at SITM? If so, when are you leaving?
Good Luck
Frank Barnhill
79 Euro AT
Good Luck
Frank Barnhill
79 Euro AT
Finally noticed the metal contact down where the hub attaches and bent the contact up just for the hell of it. Voila! Horn works.
See the (pirated) pic below. I added an arrow pointing to the contact that I had to 'carefully' bend up a bit.
Good luck. -Ed
dollars to donuts this is my problem....
Rocket Pilot
Be sure that horn button is a MOMO and not a DINO Porsche -crested button. They look and fit the same but the dino button requires a second loop for the ground. I just went through this problem!
Quick update- It was the metal strip that touches the hub. Bending it up did the trick!
Brad,
Nice to hear you got home safely and got the horn fixed I haven't cranked mine since last Sunday. Headed straignt to the beach Sunday and just got home. Can't wait to get the shark out tomorrow and go vacuum leak hunting again. I am going to take it to a good wrench in Charlotte soon but I am going to give it one more try.
