928 Forum 1978-1995
Sponsored by: 928 Specialists
Nitrous Kit ...UPDATE
Old May 23, 2006 | 04:50 PM
Larry928GTS's Avatar
Larry928GTS
Registered User
Originally Posted by Andrew Olson
Be careful, it's addictive... I know.
Yes, it's a gateway drug that leads to boost.
Old May 23, 2006 | 05:05 PM
AO's Avatar
AO
Supercharged
Originally Posted by BRETT AINLEY
Hi Andrew
Yes I know....what I am plannning is to go to 100 hp jetting.....then....start thinking about finer control..aka Maximiser controller..and maybe a wide band etc...
As you and Mark have done this..what is your opinion of the 100hp limit on single nozzle ??
Would you have gone above 100 on single or do you think that direct port (8 nozzles) is the way to go for 150 or a 200 shot ???
All the best Brett
I chickened out, but based on what some of these boostards are putting out, I think 100HP is safe and even up to 150. Key is making sure you don't run lean.
Old May 23, 2006 | 05:06 PM
AO's Avatar
AO
Supercharged
Hi. My name is Andrew, and I'm addicted to HP!
Old May 23, 2006 | 05:15 PM
Brett928S2's Avatar
Brett928S2
Hi Andrew ....maybe we should start a support group lol.....we need sponsors i think ???
All the best Brett
Old May 23, 2006 | 06:27 PM
misterfreddie's Avatar
misterfreddie
Where exactly did you route the cable through the bulk head.. Who at highpower were you dealing with ?
Old May 23, 2006 | 06:28 PM
whitefox's Avatar
whitefox
Someone needs to put together a kit with everything you need.
Old May 23, 2006 | 06:37 PM
Brett928S2's Avatar
Brett928S2
Hi
Pipe was routed above steering column (RHD)
Dave and Trev for jetting advice etc..
All the best Brett
Old May 23, 2006 | 06:44 PM
Brett928S2's Avatar
Brett928S2
Hi
Lots of companies do a kit....but for 928s its not quite that easy lol..mind you nothing is
As an example...the machined ally nozzle holder I had built....will only fit 16 valve engines as it replaces the AAV plate which 32 valve doesnt have ..I dont think
The only person who could build a COMPLETE kit is someone who has already done it...and even then...it has to be for same model...
So few do it....I got lots of advice from Andrew and Mark ..ty ty ty ty and I would willingly help any others that want to try it...but I "THINK" that I am the ONLY UK 928 on Nitrous....
Feeling lonely now lol..but when I go to 100hp jetting OVER standard....I "should" have more power than a GTS....feels better now
All the best Brett
Old May 23, 2006 | 09:08 PM
TRUESCOTSMAN's Avatar
TRUESCOTSMAN
Watch This Space!
Old May 23, 2006 | 09:30 PM
Jon B.'s Avatar
Jon B.
I've never heard anything about people having a 100hp limit on single nozzles until I came to this site. There are guys running upwards of 200+hp shots with single nozzles. The are usually dual staged instead of one big burst, but I have always thought that direct port was more for cylinder tuning than anything else. JMO
Jon
Old May 23, 2006 | 09:41 PM
zoltan944's Avatar
zoltan944
Jon
its like carburation vs fuel injected. if a carb was able to atomize and dispurse fuel to 8 cyl as efficiently they may not have changed. so you are shooting over 100hp worth of fuel and nitrous before a throttle body and hope it dispurses properly. im not saying it doesn't work, just better to get it done right.
You want to use the lowest setting that works the most efficiently. What Brett needs to do before he starts going up in jet setting is spend more money on making the kit right. He needs minimum a bottle heater and a purge valve. you are nto getting all you have out of system without atleast these items. he should get a blow down tube and some other of the stage 2 options.
Old May 24, 2006 | 06:17 AM
C.F.'s Avatar
C.F.
...........Dave and Trev for jetting advice etc..
All the best Brett
Is that Trev the boss/owner, if so I used to race against him 20 years ago , I seem to remember I always beat him
Old May 24, 2006 | 08:46 AM
misterfreddie
Its true what he says.
First use what you have got, use the purge to consistantly have the correct mix. Use the bottle heater to consistantly get the correct presure and most importantly, keep checking your plugs for even distribution of the spray. I would also go onto the 7es plugs to use first and see if the bloody thing starts in a winters morning before going to 125 or above. Its no good an extra 25hp if your car hates starting.
Just a thought.
Old May 24, 2006 | 12:08 PM
SMTCapeCod's Avatar
SMTCapeCod
NOS used to list a kit for 928s. Their catalog also listed popularity- 928 kit didn't have great standings. I think the company was overtaken by a larger conglomerate, may have dumped some of its niche applications for standardization. I wonder if ZEX has anything...
Old May 24, 2006 | 12:22 PM
SMTCapeCod's Avatar
SMTCapeCod
Default 928 Nitrous
Found the old NOS part number:
Fuel Injection Nitrous Systems
NOS systems specifically designed for the following cars may require intake
manifold modifications for injector installation and plumbing.
* 05111 Ferrari 308/328
* 05135 2.0L all Fiero 4 Cyl 1986
* 05140 Porsche 928
* 05144 2.5L Porsche 944
Probably obsolete now, and this listing doesn't stipulate the years/systems that its designed for. It was probably just a standard direct port appl.
You should take another lead off the WOT switch and use it to activate one of Carl's electric exhaust cut outs! Just kidding- no need to add more variables to the modulation of the air-fuel ratio.
Another fun link- adv as 928 NOS vs 911 TT, IIRC Race *puff*
