928 Forum 1978-1995
Sponsored by: 928 Specialists
Wrench size expert
Old May 18, 2006 | 03:53 PM
Oldtee's Avatar
Oldtee
Default Wrench size expert
I have chased part of an oil leak to the Pressure Transmitter on my 85S (early). Before I start removing and replacing things I want to give each a 1/16 tightening before I head for SITM. I suspect the transmitter is a 19MM but have no idea what the regulator housing (screw) wrench size is. I need to procure some crows feet the correct size. Help appreciated.
Note the leak was traced using leak detector. It is not the only leak from the engine. The oil pan seeps, it looks like a little oil is coming from the drivers side cam sealing ring (rear), which begs another question, (are two questions in one topic thread permitted?), can this seal be replace without removing the engine. It looks very close to the fire wall.
Old May 18, 2006 | 04:48 PM
Imo000's Avatar
Imo000
Captain Obvious
Super User
Are you talking about the gasket for the cap of the cam, at the back of the cam housing? It can be easily acessed with just removing the air filter box .
Old May 18, 2006 | 07:23 PM
Garth S's Avatar
Garth S
The large flange retaining the oil thermostat is 27mm and the transducer is 24mm.
The flange is a large bore (~50mm) with a fine thread pitch .... and is sealed with a soft metal tube style gasket ( hollow). If you do not have the 27mm crows foot, then drop the alternator to place a wrench on the flats: carefully - for this is one set of threads that shouldn't be "screwed" up - or one will be . When this is secured, counterhold and tighten the conventional gasket on the transducer.
If you want a quick 'snug up', get a 24mm crows foot on the sensor - they should both respond ...
Old May 18, 2006 | 07:29 PM
dr bob's Avatar
dr bob
Chronic Tool Dropper
I "traced" a leak from the oil sender to a power steering hose, with help and advice from 928NTSLOW (Keith) and Jim Bailey at 928 Int'l. Replaced the hose, all was well. It was not apparent that it was that red ATF in the PS system that was leaking, as it was leaving dark drips on the floor. Seems that a long term leak attracts dirt to the area, and that runs down and onto the sender when enough has leaked. It may be worth a look before you start yanking parts off.
The oil sender itself comes apart of you aren't careful, and it's a good idea to ID the terminals with a paint pen so the two wires go back correctly. Two wires, two screws, 50% chance to get it right the first time, 100% chance to get it wrong. Sounds crazy but it's true!
Old May 18, 2006 | 08:56 PM
Oldtee's Avatar
Oldtee
Thanks.
