Help- Colored vac lines behind center console ('78)
I finally have time to put my center console back in. A long time ago, my son took my labels off the vac lines going to the heat/air area of the console.
Has anyone ever seen a map or diagram of the order that these attach? I haven't found what I need in the WSM. Is it there?? All I found in the WSM told me I shouldn't have unplugged each tube as I did. Bummer.
On the S4 the order L to R is footwell, defrost, centre comb, heater valve and recirc.
The colours of the vac lines in the same order is yellow, green, orange, white and blue.
From your pic it looks the colours are different but I believe the actuator order is the same.
YMMV
YMMV
