928 Forum 1978-1995
Sponsored by: 928 Specialists
Recommended Spark Plugs?
Old May 5, 2006 | 04:14 PM
checkmate1996's Avatar
checkmate1996
Default Recommended Spark Plugs?
Does anyone have part# or recommended type of spark plug for normal driving use? Bosch I presume...
Old May 5, 2006 | 04:18 PM
whitefox's Avatar
whitefox
I installed Bosch Platinum +4 plugs a few days after I bought my car, it had a very poor idle when I bought and these work great.
http://www.boschusa.com/AutoParts/Sp...PlatinumPlus4/
Old May 5, 2006 | 04:19 PM
P928Drvr's Avatar
P928Drvr
From: 1981 928 - 1988 924(sold)- Northville, Michigan
Champion Platinum for 6 months now...runs great...
Old May 5, 2006 | 04:59 PM
zoltan944's Avatar
zoltan944
bosch copper, or NGK copper
Old May 5, 2006 | 05:41 PM
nicobel's Avatar
nicobel
Puff Daddy
Bosch copper,
I tried Platinum4+'s and had not-so-good results (YMMV)
Old May 5, 2006 | 05:46 PM
mspiegle's Avatar
mspiegle
Had the NGK Iridiums (BPR6EIX i think?), but the car was forced induction. Had no complaints and would buy again. Any of NGK's #6 heat range plugs seem to work well in FI situations. I think BPR6ES is the non-iridium plug (cheaper).
Old May 5, 2006 | 06:21 PM
perrys4's Avatar
perrys4
The Lady's Man
Dr. Bob reccommended the Bosch Coppers also. Plug number is in the owners , manual. Mine had Beru in it when I changed them out. Ran good but the Bosch copper are suppose to help with NOX reduction.
Old May 6, 2006 | 03:07 AM
Dave H.'s Avatar
Dave H.
From: Seattle - it's not Hell, but you can see it from here!
bosch copper core tripples. WR7DTC...
Old May 6, 2006 | 04:36 AM
FlyingDog's Avatar
FlyingDog
Bosch or NGK copper. Bosch #7 (WR7DC) or 8 (WR8DC) and whatever NGK number matches. I have Bosch Super Copper which are supposedly non-US only, but a local shop where I used to live had them ($9 for the set). I have had better luck in previous cars with NGK, but Bosch Copper is what is commonly recommended and factory recommended. 928s in general do not like platinum or multiple electrode plugs.
Old May 6, 2006 | 10:14 AM
Schocki's Avatar
Schocki
Beru Ultra X
You can buy them at Zims...
Old May 6, 2006 | 11:09 AM
ParkerC's Avatar
ParkerC
When I had a PPI done they found the PO had installed new platinums...They recommended I replace them with the Copper Cores...That was about 4 months ago, and I'm still running(STRONG) on the Platinums w/no trouble.
P.
88GLASIER5SPD
Old May 6, 2006 | 01:21 PM
chaadster's Avatar
chaadster
I've got Bosch Platinum +4s, too, and don't seem to have any troubles. They've been in for 3 years, 10k miles.
What would be a manifestation of spark plug trouble? Why would "platinum" plugs cause trouble?
Old May 6, 2006 | 04:05 PM
Ed Hughes's Avatar
Ed Hughes
I've got the +4's on my 911, and they run great on it. I plan on putting them in the 928, prolly next month.
Old May 6, 2006 | 10:18 PM
Alan's Avatar
Alan
Electron Wrangler
I use Bosch WR7DTC Copper tri-electrode. Just fitted a new set this last week - the old ones were worn after about 35K miles but still looked serviceable... All nicely matched wear.
Only problem is that they came with new ignition wires, rotors, caps, new timing belt, cam gears, crank gear, oil pump gear, idler bearings, tensioner rebuild, new water pump/thermostat (+flush), new radiator fan, AC tri-level switch, new oil pan gasket, new oil/filter (+flush), new fuel filter(pressure test), various cleaning & adjusting... Whew a big week (@~$4500) ... At least it does drive better - all that ignition work fixed an occasional miss issue at idle. Its actually been cheap to maintain the last 2 years (till now...)
My wife just rolled her eyes and muttered something that sounded like "money pit..."
Alan
Old May 6, 2006 | 10:56 PM
checkmate1996
According to the bosch site, platinum+4s don't work for the early models...only after 85 If I remember correctly. So I am looking at the coppers or platinum of which they do recommend will work.
