Spacer #12 is 5.75mm thick, 23mm diameter, and bored 8mm: Do NOT add more, as this centers the piston rod into the carrier arm cup --- if the correct arm is installed.
Circlip #4 is an absolute MUST.
Part numbers ending with R are casting numbers. They are not final "machined to correct shape" part numbers and thus are not listed in PET. You need to use other means to verify you have correct parts.
