Removing rear wheel spacers on 86.5
I removed my wheel spacers so I can go with a wider wheel. I got the open-end lug nuts and got my loaner wheels back on. Only probelm is the wheel studs stick out approx 1/4-1/2". Do most folks get shorter studs or will the stock screw in more?
Hey Darien....I had a similar problem with my 84 and I used the standard porsche lug nuts then placed the alloy ones on top for show. I knew it wasn't right but it worked. Good-luck...Bill
Originally Posted by Darien Nunn
Anyone else???
I haven't had centercaps on my car since, um, November. Open lug nuts. (In otherwords, cosmetics are not my primary concern). My kid once helped me put my alloy nuts on top, I drove it like that for a month or two but it didn't look that good. If I didn't care for it you probably wouldn't like it at all.
If you want the ability to go back to stock wheels at any time, then ideally you would want to keep the spacers on and choose a wierd rear offset for the wide wheels. If not, shorter wheel studs are the key.
How much of a headache is it to install shorter studs? Can you just screw on some steel open ended lug nuts (wheel off of course), cut off excess threads, and uncrew the lug to clean up the thread edges? Sound like a "damn PO" type of thing but I'd consider doing it if my commitments were long term.
Captain Obvious
Super User
Super User
Originally Posted by James-man
Yes, but you probably don't want to hear what I have to say.
Hi you could change the studs but you will have to remove the half shafts and then install new rear wheel bearings, as you must remove the hubs out of the bearings and this destroys the bearings, ,open lugs are probably the best idea
Originally Posted by Imo000
That's a good idea. But you need to do one more thing after the nuts is removed. Make sure you have a tap & dye set and chase the treads to make sure they will not ruin the lug nuts.
Mickey Mouse University would endorse pocketing the money that you would otherwise use to buy a tap and die set.
SAE would disagree with the wisdom (?) of MMU.
Either way you slice it, you may someday be referred to as "that damn PO".
When put my Fikse wheels on I decided to leave the studs long so i would have the option of putting the stock wheels and spacers back on. I just left the stud ends sticking out, it does not look that bad in my opinion.
I would only consider perfecting the lug nut issue if I was going to participate in a concours.
Originally Posted by MarkRobinson
I just cut my studs back 20mm on my black car with the black Gemballa wheels. I hate unfinished items on street cars (my opinion)
