928 Forum 1978-1995
Sponsored by: 928 Specialists
loctite help
Old Apr 14, 2006 | 04:54 PM
s928s's Avatar
s928s
Default loctite help
..I am about tho assemble the bearing cradle on the block of the motor. My question is and I did not see it under the search option discussed here..But, is there a comparable sealent i can use to reseal the girdle if the "loctite 574 " is not available? Isn't there a permatex product out there, mostlocal auto stores carry a permatex antibolic sealent (sp)...Sucks because i took the this long weekend to put the motor back together..
Any help would be appriciated, Thanks in advance, DAVID
Old Apr 14, 2006 | 10:24 PM
John Veninger's Avatar
John Veninger
Loctite 518 can also be used
