a/c control Vacuum system help please
Here it is , after 3 years and a half of puzzeling with that car, 90% of the parts are back in but i lost where a vac hose goes . It's a white hose coming from the center console , if you refer to the shop manual at page 87-2 , the one i need to find is not mentioned (white) but we see it , it goes to a Y that goes to switch L1 pin 4 and to switch L2 pin 5 then here is my problem where does it go ? Look under the letters AUS.
I'll appreciate any help
am,
check john's pirtle's website... he has a bunch on that both in the FAQ and the email keepers
http://members.rennlist.org/pirtle
Excellent website
Sincerely,
Excellent website
Sincerely,
1 Post
Thank's guys but , i checked on the proposed website and found what i already knew from the shop manual , the vacuum lines are a bit different for older model and last models . The colour in my car for the water valve like mentioned in the shop manual is red , for more recent cars it is white , just check the page of shop manual i wrote about in my topic.
Everything seems to work fine in the center console but i would'nt leave a vac line open or plugged like that.
Anymore suggestions ?
928 OB-Wan
