Water Pump Question HELP
#46
Basic Sponsor
Pictures
See below
#48
Note the six vs. two raised stiffening ribs that run up to the boss area on the S4 pump: That plus the stronger stud with M10 threads plus the cross brace suggests that Porsche were well aware of the high tension loads on the carrier pivot.
Futhermore, the tensioner body had been moved out ~8mm to center its thrust through the tension roller directly into the TB centerline. This was to minimize radial torque on the pivot stud.
A busy bunch they were - patching up a weak design
#49
Struthers... you ready for a cigarette now?
Think I'll go ....check my boss, now.
G'luck all.
p.s. somebody summarize this & put it into Keith's
"928...Did You Know" thread. TIA
G'luck all.
