928 Forum 1978-1995
Sponsored by: 928 Specialists
Smog Pump
Old Mar 4, 2006 | 01:52 PM
icsmike's Avatar
icsmike
Default Smog Pump
I was wondering if I could remove this without having any problems? It still works fine but ut just seems like its a waste of power and space. 86.5 manual live in MO (no pollution testing).
Old Mar 4, 2006 | 02:06 PM
the flyin' scotsman's Avatar
the flyin' scotsman
The easy answer is yes..............I removed mine from my S4 for the same reasons.
Not difficult but does require patience and my non-petite mitts hands some cuts and bruises when all was done.............do a search on removal.
Old Mar 4, 2006 | 02:41 PM
icsmike's Avatar
icsmike
Old Mar 4, 2006 | 03:18 PM
david928's Avatar
david928
I replaced the standard exhaust with a Xover and cats. The modern cats don't require an air pump, so I removed it.
Old Mar 4, 2006 | 03:23 PM
Scott M.'s Avatar
Scott M.
Rest in Peace
Replace the smog pump with a 22" lawn mower belt from NAPA. The new belt will allow you to run your factory mechanical fan.
Old Mar 4, 2006 | 06:55 PM
hupp's Avatar
hupp
I've read that removing the smog pump can cause issues with the catylitic converter.
Old Mar 4, 2006 | 07:10 PM
Scott M.'s Avatar
Scott M.
Rest in Peace
The main issue is now the cat is less effective, meaning its' time for that X-pipe!
Old Mar 4, 2006 | 10:33 PM
s928s's Avatar
s928s
Mine has been off for 3 years now..no problems. The air pump adds air to increase the efficiency of the catalist. does nothing else. You can go one step further. Remove the pipe on the right valve cover. The rear cross over pipe and fitting into the rear of the heads. There are 2 plugs you can install to cap off the rear head fittings. I can get the part number is needed. I got mine from Dave Rodgers at 928specialist.
