82 928 problem
My neighbor is having a problem with his 928. It is a 1982 model. If you disconnect the battery and then restart the car the stop light stays lit and when you press on the brake light above the clock and above the the O2 sensor flash all the time and will not reset until you disconnect the battery again.
Thank you
Thank you
928 Collector
Stop light stays on till you depress brake, that's normal. O2 sens light is on after a set number of miles. Unit is under passenger cover between seat and door. Can be reset.
