928 Forum 1978-1995
Sponsored by: 928 Specialists
ABS Light On - Troubleshooting
Old 02-11-2018, 12:51 PM
928wolf
928wolf's Avatar
Default ABS not working
Originally Posted by Jim M.
The ABS light (at least on a 928) does not require the hammer to reset it. I think Randy is thinking of the air bag light. Most likly a relay problem. The system is very reliable, if the ABS goes off due to a system failure, braking reverts to non-ABS braking. There are several reasons for an ABS warning light. It can be corrosion at connection points, a bad relay 928 615 124 01 on the fuse panel. Using an insulated jumper wire you can bypass the relay by plugging two spade terminals into the slots on the relay board, that correspond to pins 30-87. Be sure to identify the correct slots. Open or short circuits in the speed sensors, speed sensors that have too much metallic crud in them or on the tone ring. To be functional the ABS needs to know the speed of each wheel so if any of the sensors, connections or wires fails it shuts off and triggers the warning light. The sensors are A/C voltage generators that create a sine wave output, usually somewhere around +/- 1 or 2 volts, when the teeth of the sensor ring pass the sensor. There are two electrical tests for the sensors; a continuity test with an Ohmmeter, and a comparison of the sine waves with a scope. The problem is much more likely to be faulty connections than faulty sensors. The ABS control module compares the sine waves to see if a wheel is locking. Malfunction in the ABS valve body. The ABS light should come on when starting and go off after the few seconds of self-testing. If the ABS light stays on then it’s more likely a hardware failure than a signal loss from a sensor. Start with the ABS relay. If the light goes off, but lights again within a few moments of moving off, it indicates a sensor which passes the start-up test is now failing to send an adequate signal. If ABS warning comes on after car is in motion, then there's a differential/non signal sent to the ABS brain so the sensors/connectors may be the problem. Check the sensor connections at the wheels, a black 2" long cylinder. This could be dirt in the ABS sensor area or a flaky connection. They get loose or installed in the wrong hole (3 holes, wear sensor, ABS, and RDK). Inspect the cables for deterioration and shorts from the connector to the chassis. While the ABS light stays on, the ABS module is not operating at all, but normal brake pressure will still be applied from the brake pedal. There are two relays mounted on top of the ABS unit in the LH front fender, under a cover, behind the splash shield, partially visible from under the hood, near the power steering reservoir. The system goes active at about 35 mph. The ABS control module needs to see relatively clean pulse signals from each of the sensors. If the signal from one wheel drops out, the system will turn on the ABS light and the system will shut down. Removing ABS relay will disable ABS circuit; I drove like that with no brake loss, waiting on my new relay.
Jim Mayzurk
93 GTS 5-spd
I found this old thread that seems to address the issue I am having. ABS light goes out when I start the car, then comes on a couple seconds after I start moving. Going by what is posted above, this sounds like:
1) all of the sensors are passing the initial self-test, so they at least have continuity of are not completely disconnected, wires broken, etc.
2) but at least one sensor is not sending an adequate signal. Or all of them, who knows?
3) I'm not sure how to check for an inadequate signal. In another post it talks about looking at the sine wave coming out of each sensor. If I had an oscilloscope, which I don't, would I simply spin the wheels by hand? The only way I could get to these sensors was with the wheels off. I'm not sure this is possible with the car moving.
4) There is Bosch analyzer tool - Bosch K7-ETT 016.00/VAG 1516 or - does anybody know how I get my hands on one of those? Sounds like it could help pinpoint the problem.
5) The brute force method would be to plunk down $1000+ for 4 new sensors, but if I wanted to spend that kind of money I'm not even positive it would work.
Anybody ever have or solve this problem before? Your help would be greatly appreciated.
Thanks,
Car: '85 Euro 16V 5-speed
Old 02-11-2018, 01:09 PM
davek9
davek9's Avatar
Hi, you can check the sensor output (and wiring all the way to the ABS control unit under the dash,
Locate the unit and pull off the connector that has the wheel sensor wires going in the the controller.
The workshop manual gives the pin-outs for each wheel at the connector.
You can use a Volt meter if you don't have a scope, spin each wheel all should be about the same.
There are cheep/Free PC-Scope programs that can turn a Notebook into an O Scope using the sound card Mic Inputs (L&R) for probes,
Hardest part is building a voltage divider to step down the 12v to go into the Notebook (it's not really hard to build).
Old 02-11-2018, 02:29 PM
928wolf
928wolf's Avatar
Thanks, I'll try that next weekend.
Old 02-11-2018, 05:11 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,453 Likes on 1,378 Posts
Test the computer controller. you will need a helper to spin the wheel.
So you will have an idea where to look
NEXT
I would suggest to inspect all of the sensor wires and remove every sensor to clean the ends,
its probably time for this service.
refit the wires and sensors,
NOTE inspect the grounds at each wheel .
also clean the ground points in the spare tire well these will be the fat brown wires.
Retest the sensors at the computer connector once everything has been refitted
Old 02-11-2018, 05:44 PM
928wolf
928wolf's Avatar
My Service Manuals don't have a pin-out for the ABS controller. There is a "ABS Test Plan" that is referenced, but it is not part of the WSM, at least one I have.
Anybody know where I can find the pin-out on the internet?
Thanks,
Old 02-18-2018, 03:49 PM
928wolf
928wolf's Avatar
I did a basic continuity test on the ABS controller connector. I got about 1000 (1056 and 1060) ohms for both fronts but both rears were open circuits. Sounds like a problem somewhere between the rear sensors and the controller. From the wiring diagram in the WSM its does not look like those 2 wires ever merge into one, so it appears that both are bad or broken somewhere.
Old 02-18-2018, 08:17 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
look in the spare tire well it could be a loose plug ,
all the wires from the transmission and brakes and ABS come through the spare tire well.
Old 02-18-2018, 09:40 PM
928wolf
928wolf's Avatar
Will do, Thanks
Old 02-19-2018, 09:46 PM
928wolf
928wolf's Avatar
I didn't see anything there, except what I assume is an old, unused plug from a car phone back in the day.
Old 10-23-2019, 03:30 PM
rahulsingh
rahulsingh's Avatar
Default 968, 1994 porsche
Does the speedometer of the car also takes wheel speed sensor value... In my case speedometer is also not working with abs light on ?
Old 10-23-2019, 04:04 PM
Christopher Zach
Christopher Zach's Avatar
Not from the ABS. I had the same problem as many of the people in this thread of yore, and it came to the wires to the ABS were dragging on the rear axles and faulting to ground. That's why it comes on then off when starting, then comes on as soon as you move.
In my case I had to replace every one of the grommets that hold the ABS and brake pad wires all around the car. Bit of a pain, but do-able as they were all rotted out in my case.
Old 10-23-2019, 04:14 PM
rahulsingh
rahulsingh's Avatar
Thanks for the reply.... So do u mean that both problems( abs light on & speedometer not working) are seprate... Need to diagnose saperately... Besides these fault my battery voltage indicator is always showing 16 volt no matter what... I guess it is meter itself... Any idea on that... ?
Old 10-23-2019, 04:18 PM
Christopher Zach
Probably. I'd start though by checking all of the brake/ABS wires and grommets after putting the car up on a lift. Trying to chase ground faults otherwise can and will drive you completely mad.
rahulsingh (10-23-2019)
Old 10-23-2019, 04:19 PM
rahulsingh
rahulsingh's Avatar
Thanks Chris .... Tomorrow I am going to check it again...
Old 10-24-2019, 07:25 AM
M. Requin
M. Requin's Avatar
Yep, exactly the same issue on my 86.5.
Quick Reply: ABS Light On - Troubleshooting
