Electrical Issues - I know, shocking.
Went to a friends house, owns a 911 and a lift in his garage. Went through the car and got a ton done. Feel much better about driving it now.
1) Checked timing belt, looked good so didn't change it, will plan that for 15 or so grand more miles.
2) Checked tension, was right on!
3) Drained and refilled with distilled water and anti freeze.
4) Changed oil
5) Changed front brake pads
6) Put in new hatch shocks(don't need that 2x4 anymore)
7) Checked out all under carriage, suspension, etc, looked and felt solid, all except a cracked ball joint boot i'll have to plan to replace.
8) Now, for the electrical. Threw a light tester on it, burned my eyes it was bright as hell. Started pulling fuses, turns out the drivers side elec seat and the rear hatch realease/push up, whatever it's called were my issues. Since I really don't need either right now, left them out. Battery is perfect now, 2 weeks later, baby starts up no issue, so, don't need the 10mm wrench that i used to disconnect the ground on the battery in the back all the time either, retired with the 2x4. I will revisit the issues when I have more time. We also cleaned the ground strap on the battery, pulled out the fuse box and cleaned all the grounds behind it, 10 or so of them. There are a few more things on the list above, and i'll get back to my friends house sometime this year to get some more things done, i'll add those to my list.
Now I feel I need to check into my feul hoses since I have been reading up on Shane's horror show from a while back.
In any case, get to know my 928 day went well and she's humming now, amazing what putting some synthetic oil in her will do to cut down on the ticking noise!
As always, i troll and find great stuff on this forum, just keep adding to my list and knock em off as i go.
Thanks guys!
(did not get fired). I beleive the warning on the can stated Do not use on Polystyrene (it was the only contact cleaner we stocked at the time). Be very very careful with cleaners and read the info on the can. I think the Electrical cleaner I am using now specifically states that it will not harm any plastics.
