bushings - Upper control arm
Upper control arm
Is it the same bushings between a 928 from 1981 and from a 928 from 1988.
I dont know what I have on....
In my order from 928motorsports .... I want to order right stuff.
/Jonas
/Jonas
Hej Jonas,
you can measure the control arm on the car to define what you have.
Older version is 234mm from center of the inner bolts that goes trough the bushings and out to the center of the outer bolt.
(measured from a center point between them and outwards)
The newer arm from -86 onwards is 215mm.
If you have access to WSM it is on page 40-17 with picture and all.
There's two different kits of bushings depending on older or newer arm.
Cheers/Peter
Cheers/Peter
