Replacing MM (motor mounts) - done!!!
AUDI mechanic replacing MM ( Anchor solids).today, what should I feel? Original MM with 110k miles.
86.5 A/T
WOW, What a difference, I say anyone thinking of replacement MM do it NOW!!
I'm so glad my mechanic found the time! FINALY, AHHHHHHHH
86.5 A/T
The Lady's Man
Damn I am jealous!! Everyone says that rep[lacing badly worn MM makes a world of difference in the smoothness of the engine and that it makes the whole car feel different. Post your results so I have more incentive to go further in debt to get this fix done. Good luck.
My car had a vibration around 2.5-3k rpm which disappeared with new MMs. Also the engine sits significantly higher in the engine bay and rocks back and forth when the engine is reved from idle. Lots of work but worth it.
Perry...........do it yourself and get very intinate with your car; only expense is the RA mounts and your time.
Supercharged
Originally Posted by BIMMERMIKE
what should I feel?
The Lady's Man
Supercharged
Perry-
It really isn't a bad job. Just messy. The biggest thing is having the time. If you hade 1 full day with no interuptions, you could do it in a day. With kids and a wife, it took me about a week. No hard (or tricky) at all. Look up Pirtle's write up. It's the best.
Not a 928, but my friend with a '99 M3 just replaced his MM and I could not believe the difference in how the car shifted. It went into gears far easier and the whole car was just smoother in general. Since 928s have a different transmission-to-engine configuration, the same benefits in shifting may not be realized, but i'm sure it'll fix lots of "annoying" stuff.
Good stuff Mike.
Perry, what Andrew said "in my garage, up on jack stands, on my back". It truly is not difficult, time consumming perhaps..........follow John Pirtles instructions on his site; Tony has a good write up also............and you have no cold weather to worry about.
