Install yoiur own piston squirter
#32
I would like to revisit this topic as I would like to run higher scavenge vacuum , and higher rpm limit , so am looking for lots of comments , source of parts etc .
TIA
JG
TIA
JG
#33
There is also the trick of notching the rods to direct the bearing oil at the piston as it's passing out of the rod bearing: https://pauter.com/parts/technical/rod-info/ [scroll down to Optional Oiling]
