As far as protecting the hood paint from heat, remember the engine bay is painted with the same paint as the body and seems to hold up pretty well.
I know this has been discussed b/f but if folks are concerned about the paint in and around the hood area due to engine heat perhaps they should open the hood when they pull into the garage after a workout? It might not do anything except keep waxed areas from hazing but it will at least get rid of a lot of heat that will take its toll on plastic and rubber bits in the engine bay over time.
Thanks guys for the timely thread! The motor is still out of my GT and I have a new factory hood liner to put in. Fortunately with the motor out, it will make it easy enough to install standing in the engine bay
Thany you Chuck for the install "procedure" and old adhesive remover tip. That is great advice and will be a big help on installation
