Anyone had this problem? (turn signals)
After completing the odometer gear replacement (wheel, turn signals, pod, off) the turn signals work like this:
Left turn, momentary position -OK
Left turn, full position -no flash
Right turn, momentary position -OK
Right turn, full position -Lights flash and central hazard comes on when brakes applied.
Anybody had this?
Anybody had this?
Never had this problem...But...it sounds like an "alignment issue" to me...if the contacts are "made" for proper intermittent flashing of your turn signals, but not working for the locked on position by the steering shaft, you need to loosen and readjust the alignment of the switch on the steering shaft..It sounds to me like yours is "close but no cigar". Unless you have reason to suspect otherwise. The flasher is working properly, it would seem.
