front suspention parts help.
now that i have the new garage to work in
I have started the suspention upgrade/repairs to my 1982 euro. I have a set of adjustable front shocks to replace the old Boge ones and a set of Eibach lowering springs..but,I have a few issues. what does the lower part of the spring sit on i just have the adjuster and shock. Does the old spring pearch slip over ? It looks like the opening would not be large enough ? If the parts are different from a adjustable to a non adjustable spring pearch, does someone have a set to sell? ( or a pic of the assembled shock set-up )
I am also looking for a few additional suspention parts.
1. the upper shock mounts, both of mine are stripped
2. upper control arms
3. parts numpers for the front bearings, races and seals
..any help would be appreciated,
thanks in advance, DAVID
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
Does your adjuster have an ~ 1" tall threaded sleeve inside the slotted aluminium nut? .... and are the shocks Konis?
If yes to both, the Boge lower spring perch will fit as before - at least with OEM springs. If the diameter of the Eibach is identical to the removed spring, then you are good to go.
I can dig out the cup & cone numbers later if you do not find them.
edit: this bearing deal may be of interest ...
I an installing 928 343 055 09 BOGE on the front. I currently have non adjustable fronts. I do have the threaded collars and adjysters, I do not know if the lower spring pearches are useable. I cannot find a part number . any help ??
thanks in advance
thanks in advance
