928 Forum 1978-1995
Sponsored by: 928 Specialists
Latest 1/4 mile time slip
Old 01-30-2006, 11:42 AM
  #31
Gretch
Range Master
Pepsie Lite
Gretch's Avatar
Received 1,235 Likes on 755 Posts
Originally Posted by Jim R.
Tony,
Nice run!
Damn, I wish we had a local track here still. Only so much you can do on the street.
It would be interesting to see how a higher stall torque converter and drag radials would work for you.
Jim
I agree with Jim, Good stuff Tony!!!!!!
Old 01-30-2006, 12:27 PM
  #32
Tony
Tony's Avatar
Originally Posted by m21sniper
All the ambers light at once, then the green(at .5 intervals). The pro tree only takes 1 sec to cycle vs the 1.5 sec of the amatuer tree. ..................
I wonder why they use two different systems.
Thats what our tree was running that night...presatge..stage...then ALL 3 yellows at the same time...and GREEN.
Last season they actually had a traffic light..., seriously.
The amber light was prestage...when the red light came on you STOPPED, staged.....then the green light would go on....GO... SIMPLE.
Ill see if there any videos out there from that night...there sometimes are.
Old 01-30-2006, 12:37 PM
  #33
Tony
Tony's Avatar
Originally Posted by mark kibort
are you running a 1/4 tank too? If so, what are you taking those bum gallons for a ride for???? get it right before the reserve light goes on! 1/4 tank could be 20 extra lbs right there.
109mph top speed, what rpms are you at when you cross the line? 2.2 auto?
how about tires. drag DOTs???
great job, thats fast!
maybe you do need that 3.09 on the auto!
Mk
Your all gonna kill me for this guys, as i can see where this will all go, but i tell ya what MARK, the drop of in rpms on the 2-3 shift is really what kills the speed and time in my car. 3rd gear is too tall from 2 and it feels like eternity for the rpms to climb like they do in 1st or 2nd. Ill post the data log today and you will see how rpm climbs compared to 1st and 2nd
yeah, when i get picky, i will drop the passenger seat, amp, rear seats, glove box junk tool kit.....soda bottles etc etc
Old 01-30-2006, 12:40 PM
  #34
Tony
Tony's Avatar
Originally Posted by Imo000
Mark,
To run a 109mph in an ’85 5-speed, 3rd gear is almost enough to run the ¼ mile. Because it’s almost enough I have to shift into 4th otherwise the rev limiter would kick in ~50 ft before the finish line. Even though the rev limiter was slightly raised by the chip change it was still not enough to run the car without shifting into 4th.
I never make the shift into 4th...not even close. in my 2.20 auto
Old 01-30-2006, 01:09 PM
  #35
Imo000
Captain Obvious
Super User
Imo000's Avatar
Tony,
Yup, you are right. The auto trans shouldn’t even be close to 4th at the finish line.
Is the data logger part of the G-tech or is this something else?
Old 01-30-2006, 01:31 PM
  #36
m21sniper
m21sniper's Avatar
Sniper,
I’m not sure why there are two different methods to activate the tree, but ever since I’ve been going to the track (+10 years) I never seen the pro tree in use during an non NHRA competition. They do use it during “test & tune” days but only for cars that are NHRA legal.
At ATCO they have days where you can line up and get the pro lights, but the R/T is always .001 perfect. I wish i kept some pix last time from the track, they showed my RT time of .101 on the scoreboard, but they were pretty blurry so i just tossed them(my drunken uncle took them, lol).
Old 01-30-2006, 01:33 PM
  #37
m21sniper
m21sniper's Avatar
I just barely shift into 3d in my A/T 2.20 car. Probably about 100 feet from the traps i guess. Having a second gear that will pull into the low-mid 90s will cause that.
LOL.
Old 01-30-2006, 03:04 PM
  #38
Tony
Tony's Avatar
http://www.innovatemotorsports.com
i have teh Aux box as well. I have it set to Log afr, rpm, boost, dwell, fuel pressure, I/C discharge...it will log anything you can make a sensore for. Next one im going to try is ignition timing.
Ill run down and pull the files off my laptop.
Old 01-30-2006, 03:44 PM
  #39
Tony
Tony's Avatar
this is the 12.8 log
vertical green line is the appx start..redline appx finish 12.8sec later.
The thin grey/black lines mark the area where the data tags along the bottom were taken.
the orange line is fuel presure. The numbers are correct not the unit of measure(volts).
The RPM is appx 200-300 rpm high from what i can gather, not sure why. Ive tried numerous settings on the set up.
HTH
Old 01-30-2006, 04:00 PM
  #40
Tony
Tony's Avatar
This is another data log from my last best, 12.9sec back in April for comparison.
Old 01-30-2006, 04:11 PM
  #41
Imo000
Captain Obvious
Super User
Imo000's Avatar
Looks like in second gear the injector are maxed out but the A/F radio is still good. You must be running right at the limit of what the injectors can produce. I was told that if the duty cycle goes over 80% its time for bigger injectors. Are you upgrading when the smaller pulley comes?
This is a neat tool, it really does show everything that you need.
Old 01-31-2006, 12:22 AM
  #42
m21sniper
m21sniper's Avatar
Yuppers, that's a pro tree.
OMG, LOL!
Old 01-31-2006, 12:24 AM
  #43
m21sniper
m21sniper's Avatar
Are you flat shifting tony?
If not, that does help a little bit with RPM drop.
Old 01-31-2006, 09:58 AM
  #44
Imo000
Captain Obvious
Super User
Imo000's Avatar
Flat shifting?!?!?!?!?!........ now that's a term even I never heard before. I need a definition on this one Snipe.
Old 01-31-2006, 12:42 PM
  #45
m21sniper
m21sniper's Avatar
Shifting a manual transmission without taking your foot off the gas.
Very common term in these parts.
Quick Reply: Latest 1/4 mile time slip
