Cam cover venting
Road Warrior
I'd thought about just using the air pump inlet attached to my gts pvc line, but chickened out cause I didn't want to spray oil onto my cats.... suppose a seperate vac pump could be used, but the issue of what to do w/any oil that might be removed seemed kinda messy (ie catch cans, etc)... \
I suspect a dry sump would be the way to go if one really wanted a nice HP gain, bullet proof oiling... might have even helped out w/jim's little "inversion" issue too - course I'm not sure it would've helped w/the "body work" much ... hehehe
