how stiff is too stiff? (suspension)
#31
Originally Posted by Greg Gray
I second that question as I already have bilsteins and want to know what to do with the springs, I do want to lower the weight so a tightly wound style is the only way I would go.
Cheers Greg
Cheers Greg
My recommendation is to try the bilsteins on with stock springs first...and then move to stiffer springs if you feel the need. I found out the hard way what Jim Bailey had been preaching for years: Change ONE variable at a time when it comes to suspension. This method means more labor installing and replacing, but it beats never getting to the right combination for your taste. I would experiment with the rears first, as they're much easier to work with than the fronts....unless of course you're lucky to experience the desired effect in someone else's car and you just simply copy and install only once
#32
Originally Posted by FlyingDog
Thanks for the info Tarek. What rate springs are you using? I wonder if anybody (preferably nearby) has tried Bilsteins and Hypercoils on a more stock 928.
The ride is undoubtedly stiff. It may be an acquired taste (it was for me). I'm also running street/track tires that have super-stiff sidewalls which also hurts ride quality. If you're ever in the San Francisco Bay Area, you're more than welcome to come for a ride and feel what it's like.
#33
Thanks for the offer Dennis. You don't happen to know what spring rate is ideal for stock Bilsteins is, do you? My car isn't exactly gentrified in other ways, so I'm not too concerned about ride stiffness unless it's bone jarring.
Tarek, I'm getting a used set of rear Bilsteins, so your advice on doing them first sounds good. That is unless I keep my current car. It needs motor mounts and a few other things up front so I might as well do the fronts while I'm in there.
#34
If you're not afraid of ride stiffness then you may enjoy the ride. The reactions of people who ride in my car range from "not as bad as I thought" to "I feel like I'm going to throw up."
#35
What makes the ride feel hard is the dampener not the springs. I have 800 lbs/inch in front and 525 at the rear with Leda adjustable shocks. When I drive on the street I put them on full soft which makes the ride quite ok, the when I hit the track I put them harder which makes the ride on the street quite bumpy.
I first tried with 600/400 springs and it's not that big difference from 800/525.
#36
Rehan What makes the ride feel hard is the dampener not the springs. I have 800 lbs/inch in front and 525 at the rear with Leda adjustable shocks. When I drive on the street I put them on full soft which makes the ride quite ok, the when I hit the track I put them harder which makes the ride on the street quite bumpy.
Cheers Greg
#37
Greg, I was in a group buy and got a great price. But I think that they were close to 1200 Euro, which is around 1300 USD I believe (front and rear incl. springs, rose joints and helper springs). I bought mine a year ago and the prices might changed since then.
#38
That's only a little more than what I paid on hypercoil/bilstein
