2006 Northstar 4.4L V8 SC (LC3) similar to TS 928
These are the specs for the new TS Caddy engine. Does anyone know the boost?
Type: 4.4L V8
Displacement: 4371cc ( 267ci )
Compression Ratio: 9.0:1
Valve configuration: dual overhead camshafts (4 valves per cylinder)
Assembly site: Performance Build Center, Wixom, Mi.
Valve lifters: roller follower with hydraulic lash adjusters
Firing order: 1 - 2 - 7 - 3 - 4 - 5 - 6 - 8
Bore x stroke: 91 x 84mm
Fuel system: sequential fuel injection
Horsepower: 469hp (349kw) @ 6400 rpm ( STS-V ) SAE Certified
443hp (330kw) @ 6400 rpm ( XLR-V ) SAE Certified
Torque: 439lb-ft (595Nm) @ 3900 rpm ( STS-V ) SAE Certified *
414lb-ft (561Nm) @ 3900 rpm ( XLR-V ) SAE Certified *
Fuel shut off: 6700 rpm
BIN 8 / EURO 4 compliant
Close-coupled catalytic converters
EGR and A.I.R. not required
Applications: Cadillac STS-V
Cadillac XLR-V
Block: ( upper ) sand-cast 319 T 7 aluminum
Block: ( lower ) die-cast aluminum
Cylinder head: 319 T 7 semi permanent mold cast aluminum alloy
Supercharger / Intake: GM patented integral design.
GM specific helical Roots rotor set, cast aluminum case. Four
laminova style intercoolers
Exhaust Manifold: cast nodular iron
Crankshaft: Forged steel with rolled fillets
Camshaft: cast nodular iron
Connecting rods: powder metal with heat treatment
Intake and exhaust variable valve timing
Piston oil spray cooling
Polished exhaust ports
* 90 % of peak torque available between 2200 and 6000 rpm
Platinum tip spark plugs
Type: 4.4L V8
Cadillac XLR-V
yes the specs are for the V series (supercharged), I own a 96 SLS and the northstar is very impressive but the downfall is the speed limit is electronically limited to the tires speed rating, in my case 112 mph, and from what I understand it is VERY hard to get it removed.
Not sure if this is true for the newest generations of cadillacs.
I still don't know the boost with Caddy's 9:1 CR; based on the 4.6 liter 10.5:1 hp of 320, I'm guessing about 9-10 pounds of boost with the smaller bore 4.4 liter 9:1 CR Twin Screw to make 469 hp. I like the integrated laminova intercooler.
Thank you for contacting Cadillac again. We apologize for any frustration or inconvenience. According to our resources, we do not measure the boost for a supercharged engine but only for a turbocharger. For more information, please contact the service manager at your Cadillac dealership.
To make your purchase of the STS-V even easier, take the opportunity to participate in the Personal Assistant program! This service is offered to you at no cost and without any obligation to join. A Personal Assistant can be there for you throughout your entire purchase experience, assisting you with locating a dealer, providing vehicle feature and option information and much more! If you are interested in the Personal Assistant program, please visit www.cadillac.com or call 1-877-PA CADDY (1-877-722-2339).
We hope that this information answers your question. If you need additional information or have further questions, please let us know via email or by calling Cadillac at 1-800-333-4223, between 8:00 a.m. and 11:00 p.m., Eastern Time, seven days a week. Thank you for contacting Cadillac!
Sincerely,
Ann McManamee
Customer Relationship Manager
Cadillac
Sincerely,
Ann McManamee
Cadillac
Well, according to C&D, I'm wrong with my guess of 9-10 pounds boost, they say it is 12 pounds; not bad for 9:1 CR and 50,000 mile warranty
Cadillac STS-V
Is 440 horsepower enough to keep up with the German hot-bloods?
BY CSABA CSERE
February 2005 Car & Driver
Cadillac is determined to make inroads into the luxury market that's been dominated by the Germans for the past 30 years. The Detroit brand has steadily been introducing strong new products over the past three years. And like the premium automakers in Germany, Cadillac has established a performance division to attract wealthy hot-bloods as well as enhance the appeal of the entire division.
The first of these hot-bloods was the Corvette-engined CTS-V that appeared last year. Now Cadillac has unveiled a hot-rodded version of the STS, the division's newest product. This STS-V eschews the pushrod Corvette V-8 in favor of the well-established 32-valve, four-cam Northstar V-8, one that is, for the first time, energized by a Roots-type supercharger.
Spinning at 2.1 times crankshaft speed, the supercharger, which displaces two liters of air with each revolution, creates 12.0 psi of boost in the intake system. The inevitable temperature rise produced by this compression is ameliorated by four Laminova cooling tubes with closely spaced fins within the intake manifold. This intercooling system has its own dedicated heat exchanger in the STS-V's nose.
The Northstar engine gets the expected changes and upgrades demanded by this supercharging. This includes increased cooling flow within a reinforced block, oil-cooled pistons with a reduced 9.0:1 compression ratio, stronger rods, and a bore reduction from 93 millimeters to 91, reducing displacement from 4.6 to 4.4 liters for improved fuel economy.
To make the most of the supercharger's forced feeding, the Northstar SC, as it's called, also gets a low-restriction intake and exhaust system and Extrude Hone exhaust ports (imagine a really thick and highly abrasive toothpaste forced through the ports to smooth any rough edges).
All of this adds up to 440 horsepower at 6400 rpm and 430 pound-feet of torque at 3600 rpm. That's a useful 120-hp improvement over the standard STS V-8, but it doesn't exactly set new standards for the class. The R versions of the Jaguar S-type and XJ have 390 ponies. The Audi RS 6 had 450 horses. The Mercedes E55 has 476 horsepower. And the upcoming BMW M5 will have 500.
Still, this is enough power to keep the STS-V competitive, especially as it is coupled to a brand-new six-speed automatic transmission, the GM 6L80. With a 6.00 ratio spread between first and sixth gears, this transmission should be able to fully exploit the blown engine's broad torque curve while delivering decent fuel economy. The transmission also provides for manual gear selection as well as Cadillac's excellent Performance Algorithm Shifting, which makes the transmission feel at home on tracks and winding roads.
To match the 38-percent power increase, the STS-V gets numerous chassis changes. The front and rear cradles are reinforced. The engine is lowered to provide clearance for the larger transmission. The front and rear springs and the anti-roll bars are stiffer by 10 to 20 percent, along with much stiffer compression damping in the monotube Sachs shock absorbers. Even the steering gear was changed to a slightly quicker ratio to improve responsiveness.
BY CSABA CSERE
