interior light delay
I have a 94 gts. The lights stay on all the time(except in the off position). Can the interior light delay be malfuctioning and where is it?? The door switches and the truck switch are ok.
The alarm unit is expensive - so probably the last thing you want to swap out.
Test the alarm unit inputs that trigger the interior lights (see they switch with the doors) - make sure there is nothing connected to interior lights - remove the alarm unit and see if the light stays on... if the interior light feed (which is a switched ground) shorts out to gnd anywhere it will always be on...
Do any oif your interior lights not work correctly ? if so dismantle & check for a shorted line (to gnd)
Especially test the rear hatch switch (just unplug it) since that drives the interior lights directly - everything else is via the alarm "relay".
Alan
Alan
Try the trunk switch, mine had shorted once and the lights would stay on all the time in either position unless turned off. This will also drain your battery because the red safety lights on the end of each door will never extinguish, even with the doors closed.
Thank You all for your replies.
I have unplugged the trunk switch with no positive results. Is the alarm unit under the pssenger seat for the GTS?
thanks
Merry Christmas
larry
thanks
Merry Christmas
larry
Yes,
Right in the middle under a metal cover - you must remove the seat.
There are 2 connectors. See this recent thread for a connection diagram: (page 2)
https://rennlist.com/forums/showthre...eferrerid=6055
Alan
Alan
