928 Forum 1978-1995
Sponsored by: 928 Specialists
DIY automatic shifter light
Old Dec 11, 2005 | 07:48 PM
NickT's Avatar
NickT
I'm amazed at how cheap these are.. Either that or I expected a Porsche type price on them... Anyway, which ones did you use for the doors and overhead lights? 6 or 9 leds? and do you recall what size they are? (Length in mm I mean)... I'm guessing 39 or 42mm. Might be cool to have red interior lights. At $1.95 each you really can't go wrong.
TIA
Old Dec 11, 2005 | 08:00 PM
Schocki's Avatar
Schocki
I used the 39mm LED's but they are slightly too short. I would recommend the 42mm, both have 6 LED's inside and the same level of brightness.
If you use 39mm you need to bend the contacts slightly, that's all.
I also changed the light in the glove box and behind the glove box (passenger footwell). They are different, but I can't remember the size. So measure these before you buy...
Old Dec 11, 2005 | 09:03 PM
Mark's Avatar
Mark
Originally Posted by Schocki
BTW guys you are right. The clock light dims, but the LED in the shifter stays at the same illumination level regardles what I do.
LEDs are unaffected by dimmers....they are either on or off.
Old Dec 11, 2005 | 09:15 PM
Chuck Schreiber's Avatar
Chuck Schreiber
Shock,
That looks awesome!
Looks like it's time to upgrade the interior lights as well!
Old Dec 11, 2005 | 10:13 PM
Schocki's Avatar
Schocki
The best part of this conversion is, that you can detail your car all day without draining the battery!
Old Dec 12, 2005 | 01:58 PM
Randy V's Avatar
Randy V
25 Year Member
Any feedback on my previous question, Schocki?
Looks like you may still need to replace the bulb that illuminates the HVAC controls - in your pics it appears to not be illuminated.
Old Dec 12, 2005 | 03:00 PM
NickT's Avatar
NickT
Just ordered a set to replace my interior lights. Red for the footwells (door lights) and light in the hatch, and white for the two overheads.
Old Dec 12, 2005 | 06:11 PM
docmirror's Avatar
docmirror
Shameful Thread Killer
Default LED dimmers
http://news.thomasnet.com/fullstory/468658/rss
Dimmers for LEDs. 5-36VDC source, up to 1A output. Don't know if that's 100% duty cycle or not. Prolly is.
Doc
Old Dec 12, 2005 | 06:50 PM
Alan's Avatar
Alan
Electron Wrangler
Actually LED's can be dimmed quite effectivley by changing the current through them with a series resistance. These builb replacement LED's are actually an array of LED's and a built in series resistance designed for ~12-14v operation. Changing the voltage across this combined unit does still change its current & brightness...
The problem is that this LED bulb voltage to brightness response is very different to incandescent bulb responses. So the dimming circuit in the car changes the voltage only a small amount for a relatively major change in incandescent luminous output. For the same voltage change the LED luminous output changes more linearly and just a little...
While an alternate voltage based control or a PWM (pulse width modulation) control could give you effective seperate LED dimming, what's really needed here is a circuit that takes the dashboard illumination voltage and dynamically changes the voltage variation to a larger range... very possible but more difficult to do...
If you are just worried that the brightness - while ~fixed is just too high - you can modify that with a fixed additional series resistance. If you get to the right levels you may find that the LED appears to dim more due to the human eyes sensitivity to different brightness levels - which is also non-linear.
Alan
Old Dec 12, 2005 | 07:26 PM
Schocki's Avatar
Schocki
I was thinking that you wanted to put the light strip directly under the white plastic. But the way you described it, it shouldn't be a factor.
My HVAC light is OK the first picture was taken with doors open only. If you look through the right side of the steering wheel in picture #2 you see parts of the unit being illuminated.
Old Dec 12, 2005 | 07:46 PM
jeff jackson's Avatar
jeff jackson
Unhappy
Alan...
By "series resistance"...you mean a pot ??? can a potentiometer be spliced into the 12V supply to the LEDS...to allow "dimmer" capabilties ? As low as the current draw of LED lights is...would a small "fader" type potentiometer wired in series to the 12V supply source be an acceptable means of providing the series resistance ? Or do you need to vary the potential to ground ??
Old Dec 12, 2005 | 08:15 PM
944kid's Avatar
944kid
Would a variable resistor do the trick? I think I remember hearing something about those in Automotive Technology.
Hope that helps,
Old Dec 12, 2005 | 09:33 PM
Alan's Avatar
Alan
Electron Wrangler
A variable resistor would be fine - in series - you need to limit the current - typical bright LED's consume ~20mA in bright mode so @ approx 13.5v you would likely already have (13.5v - 1.4v*)/(20mA x5) = ~120ohms in series (internally) for a 5 LED lamp.
You'd want an additional series resistor of say ~5x(+) that value for effective dimming (not down to Zero) So say ~600 ohms for the variable resistor.
You could use a variable resistor of 680ohm/720ohm that would work OK (common values). You would need a 1W resistor at least though and common variable resistors are less than this - you'd likely need a wire wound type and it would be bigger and more expensive than common carbon film types (of maybe .25 watt). If you just wanted to experiment to identify a good fixed brightness level - 1 watt fixed resistors in 10, 50, 100ohm values could be used in series to experiment to find a good fixed value. If you had multiple LED bulbs you'd need different values (lower) and higher power versions...
Alan
NB * LED's drop a forward voltage of approx 1.4v
