Auto - 89 into a Euro 85 2 Valver
The floor pan hump between the seats is much larger on the late cars to accomidate the larger diameter "bellhousing" for the bigger torque convertor used on the later trans the torque tube is the same. You might need a bit of body work (large hammer) to fit the 89 trans but that is about it.
I put an 89 A/T in my ex 86.5. Needed to replace shifter cable and kickdown cable.
