German to English (translation?)
The following words are those I couldn't translate from Theo's website (The Netherlands)
http://home.wxs.nl/~Jennit/Technical/Tips/MyTip544.htm
He has listed the Cd of various Posche models.
Flachbau, Hechlügel, Jubi, Bongers, Elfertreff zusammengstellte, MG, enstprechen den Elfern
Rick
85 32v modified
Rick
85 32v modified
Cottage Industry Sponsor
Flachbau - slant nose or flat building
Heckflügel - rear wing
Jubi - ??? (could be a short form for Jubiläum - anniversary)
Bongers - ???
Elfertreff - Meeting of '11s (911s)
zusammengstellte - put together
MG - ??? (maybe the initials of Markus?)
enstprechen den Elfern - similar to '11s (911s)
Bongers - ???
Originally Posted by Nicole
Bongers - ???
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
Nicole,
Thanks, I was hoping you'ld respond. Here is the list from Theo's website translated into English the best I could per Nicole and Babel fish.
Rick
85 32v modified
I found a list by Markus (MG) from the list put together by the 911 meeting that is quite interesting and contains a lot of Cd values:
Air resistance factor (Cd) x Front surface (A) m2 = air resistance index
356/1 GMÜND 1948 (open with 2 persons): 0.45 x 1.41 = 0.648
356/2 GMÜND Coupé and Cabrio 1948 to 1950: 0.29 x 1.62 = 0.469
356 to MJ 1952: 0.296 x 1.677 = 0.496
356 to MJ 1955: 0.365 x 1.692 = 0.618
356 Speedster to MJ 1958. Convertible D 1959: 0.377 x 1.640 = 0.618
356 A: 0.365 x 1.692 = 0.618
356 B: 0.398 x 1.611 = 0.641
356 B roadster: 0.386 x 1.599 = 0.617
356 B 1600 GS Carrera GTL (Abarth): 0.389 x 1.495 = 0.581
356 C: 0.398 x 1.611 = 0.641
550 R-S Spyder: ?
904 Carrera GTS: 0.383 x 1.401 = 0.536
914.1.7 (also 914/6, 914/8, 914/8 SII) MJ 1970 to MJ 1973: 0.38 x 1.60 = 0.608
914.2.0 MJ 1973 and 1974: 0.38 x 1.60 = 0.608
914.2.0 MJ 1975 and 1976: 0.377 x 1.60 = 0.603
924 (MJ 1976 to 1979): 0.36 x 1.76 = 0.634
924 (starting from MJ 1980): 0.33 x 1.79 = 0.591
924 turbo (931): 0.34 x 1.79 = 0.609
924 Carrera GT (937): 0.34 x 1.82 = 0.619
924S (946): 0.33 x 1.81 = 0.597
944 (also S) MJ 1982 to 1989: 0.35 x 1.82 = 0.637
944 turbo (951) (also S2, turbo S, 968 CS, 968 turbo S): 0.33 x 1.89 = 0.624
944 S2 Cabrio MJ 1989 to 1991 (also S2 Cabrio, turbo Cabrio, 968 Cabrio): 0.36 x 1.87 = 0.673
928 MJ 1978 to 1982: 0.41 x 1.95 = 0.799
928 S MJ 1980 to 1986: 0.38 x 1.95 = 0.741
928 S4 MJ 1987 to 1991 (also CS. GT): 0.34 x 1.98 = 0.673
928 GTS MJ 1992 to 1995: 0.35 x 2.02 = 0.707
986 Boxster: 0.31 x 1.93 = 0.598
986 Boxster S MJ 2000 to 2002: 0.32 x 1.93 = 0.617
987 Boxster: 0.29 x 1.96 = 0.57
987 Boxster S: 0.30 x 1.97 = 0.59
987 Cayman S: 0.29 x 1.98 = 0.57
955 Cayenne (V6) MJ 2004: 0.38 x 2.78 = 1.056
955 Cayenne S (and turbo) MJ 2003 + 2004: 0.39 x 2.78 = 1.084
901 1964: 0.363 x 1.685 = 0.612
911 MJ 1965 to 1967 all types (also Targa and S): 0.363 x 1.685 = 0.612
911 MJ ' 68 (all types): CD x A (m2) = 0.381 x 1.6853 = 0.642
912: Similar to 911 of respective model years
911 MJ ' 69-'73: Cd x A (m2) = 0.408 x 1.71 = 0.697
911 RS MJ 1973: 0.397 x 1.73 = 0.686
911 MJ 1974 to MJ 1977 (also S. Targa): 0.39 x 1.76 = 0.686
911 SC MJ 1978 to MJ 1983 (also Targa and Cabrio) and Carrera MJ 1974 to MJ 1977: 0.40 x 1.77 = 0.708
911 Carrera 3.2 MJ 1984 to MJ 1989: 0.39 x 1.77 = 0.690
911 Carrera 3.2 MJ 1984 to MJ 1989 with front and tail spoiler (also Clubsport):0.38 x 1.77 = 0.672
911 turbo (930) (also WTL, SC/RS, turbo slant nose): 0.39 x 1.86 = 0.725
959: 0.31 x 1.92 = 0.595
964 (also R-S. R-S America, R-S N/GT): Cd x A (m2) = 0.32 x 1.79 = 0.573
964 turbo (994). (Frere): Cd x A (m2) = 0.35 x 1.88 = 0.658
964 turbo (994) (also WTL, Jubi) (Bongers): 0.36 x 1.89 = 0.680
964 turbo S lightweight construction (994) (also R-S 3.8. turbo 3.6, turbo 3.6 low rise building): 0.35 x 1.89 = 0.662
993 (also R-S): 0.33 x 1.86 = 0.614
993 R-S Clubsport (with rear wing 0 Angle of incidence): 0.34 x 1.86 = 0.632
993 R-S Clubsport (with rear wingl 9 Angle of incidence): 0.36 x 1.86 = 0.669
993 GT 2: 0.34 x 2.04 = 0.684
993 turbo (also 2S. 4S, turbo Cabrio): CD x A (m2) = 0.34 x 1.93 = 0.656
996: Cd x A (m2) = 0.30 x 1.94 = 0.582
996 4S: 0.30 x 2.00 = 0.60
996 GT 2: 0.34 x 1.96 = 0.666
996 GT 3 MJ 1999 to 2001: 0.30 x 1.95 = 0.585
996 turbo: 0.31 x 2.0 = 0.62
997: 0.28 x 2.00 = 0.56
997 Cabrio: 0.29
997S: 0.29 x 2.00 = 0.58
997S Cabrio: 0.29
980 Carrera GT: 0.396 x 1.94 = 0.768
Theo
1988 928S4 cherry talk
The Netherlands
Rick
85 32v modified
550 R-S Spyder: ?
997 Cabrio: 0.29
997S Cabrio: 0.29
Theo
The Netherlands
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
I think you will find that by Bongers he is referring to data provided by Marc Bongers.
Marc is a German Author who worked for Porsche for many years. He is now the Sales and Marketing director of RUF.
You will see in the line above the (Bongers) is (Frere) which clearly means he is using info from Paul Frere.
Pity the guy did not check his data though. No such animal as a 994.
Ciao,
Adrian.
Ciao,
Adrian.
I think everybody will understand the information given. That's what counts most. Thanks for posting this!
Now let's hope Randy doesn't move it to the General Porsche discussion board where we'll never find it again...
