Light in the Engine Compartment
My 93 GTS's hood light goes on as soon as the hood latch is pulled. I thought that the light was only supposed to come on when the lights are on?
Was there a change for the GTS'?
-Kevin
-Kevin
Electron Wrangler
Kevin,
Mine comes on whenever the hood is open also - thats how its wired not sure when from - but I think it may have changed with the electric aim adjusters on Euro's since it is wired in the same loom (that is otherwise empty on US cars)
Alan
Alan
Dean of Rennlist, "I'm Listening"
My engine compartment light does the same thing. Comes on when the hood is opened (maybe when it's unlatched) whether the headlights are on or not.
Well, I like to pop the hood to draw the heat off the engine to save the rubber bits in the engine bay. I think I'll unplug it from now on.
Thanks.
Thanks.
Are you guys saying the light comes on even when the motor is NOT running and the hood is opened?
Kevin, I do like you, when I shut the car off I open the hood to help get rid of the heat and preserve the bits in the engine bay. NONE of the under hood lights on any of the 3 GTS I've owned have come on with the engine off and the hood opened. In fact, the 78 is on the lift with blue GTS is sitting underneath and the hood open for the last few weeks and no lights on. The lights only light up when the engine is running and the lights are on and the hood is opened. Go figure.
Rennlist Sponsor
This "change" happened in 90 or 91 with the newer style hood light.
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
![](http://www.928gt.com/images/928Specialists-COVER3-928GTcom.png)
928 Collector
Originally Posted by Tony
Sounds like your LH is going bad
i dont know, it would be a smart idea i think.?
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
You guys are a bunch of funny bastards.
Sub its on the pass side attached to the hood and mine only comes on when the engine is running and headlights are on at least thats the last time i saw it in my euro. There is a little pressure switch right near the brace bar.
BTW light malfunction is a sure sign of tranny failure!
Yep, just went out and double-checked mine. It operates just like the interior courtesy lights. Pop the hood with the car off and no headlights on, and it lights right up.
Does this mean I need a 3.09 rear axle?
