windage tray for 16v
Originally Posted by GlenL
That'd be really handy: a rev limiter controllable by lateral Gs. So far I'm using the grey matter (questionable).
The "soft rev limiter" cuts every second spark at a set rpm(can be controlled by a G-meter), then at a higher rpm cuts ignition totally. I have been told it just feels like the power curve drops off, making you reach for the next gear, without the sudden juddering by the standard rev limiter. Hopefully that will be good for both engine and driver...
Maybe a G-meter could be used for traction control, modulating the throttle for maximum acceleration?
