928 Forum 1978-1995
Sponsored by: 928 Specialists
Check engine light?
Old Nov 1, 2005 | 08:25 PM
Sab's Avatar
Sab
Default Check engine light?
My check engine light started to come on a few times lately during heavy acceleration. But today it came on and off cruising on the highway.
All systems seem normal, car idles fine...
What could have changed and cause this? I read that this is emissions related.
AFR meter looks like always.
I have about 9k miles since installing th eaton SC.
Old Nov 2, 2005 | 05:33 AM
John Speake's Avatar
John Speake
Hi Sab,
Could be nothing more than an intermittant lead/connector. Have a good look at Temp sensor 2 connector and wiring. If this goes open or short circuit the LH ECU will revert to a default "normal temprature" setting, and will output a fault code.
The check engine light is for emmission type faults.....
