MAF conversion kit
One of these days...
I was going to find a wrecked 5.0 L mustang and laterally transfer the brains, MAF, harness, injectors and possibly the rails to a sHARk.
Availability and programable are the two operative words here.
From what I've read a good running stang and sHARk have very similar torque and HP curves.
Baselining may or may not be necessary.
Think of the number of stang brains laying around as opposed to the limited number of ALL sHARk brains. Get to work John Speake... there's money and HP to be made here.
True the mustang is very close to the 16v but is the firing order the same? What about referencing a cam signal? Does Ford ignore the 02 reading after 2500 RPM? Opening up the intake with a MAF is all that's needed. I bet it can be done $500-700. Lot cheaper w/o software involved, just an analog converter.
Gluteus Maximus
If you retain the stock L-Jet its not possible. The brain is too old with too little brain for a MAF.
Your best bet is to convert to standAlone EFI like MS
Man of many SIGs
If you want one of the Split Second systems that John Kuhn spoke about earlier in this thread he has an extra one now. You can contact him through Pelican or his website. We took one off of one of his brothers twin turbo 16v car to convert it over to Megasquirt II. The reason for the conversion was that the split second only allows fuel tuning. It has no way to adjust the spark timing. I wouldn't use this system if I were you. The other aftermarket systems such as Megasquirt etc are much more sophisticated.
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Cool to know someone got it to work but at that point you would be 2/3 the $ into a decent MS setup.
Correct, the motor came with CIS but I put it in a 82 with L-jet. I used the larger throttle body and plenum with the US runners.
The only mods at this point is I had to fit the throttle position switches to the throttle body and enlarge the u-bend.
Brad
Brad
Man of many SIGs
How did you route the cold start. I keep hearing that the Euro heads are drilled into the exhaust vs the US heads being drilled into the intake ports. This means that if you assemble the Euro heads with an L-Jet system and hook it up just like it is on the US model, you will be dumping the fuel from cold start injector into the exhaust.
