cold weather start problem on '86.5
I know this has been discussed before... When my '86.5 is cold and I start her up the idle is low and rough for ~ 5 seconds before idling perfectly. Sometimes the engine will die within those 5 seconds but when I start her back up everything is fine. Sometimes if I attempt to accelerate immetiately after the idle stabilizes the car will not respond to the accelerator and after a few seconds it accelerates perfectly. I think I read all the posts there are on this and it seems the idle stabilzer is always suspect. In those posts the temp fix is to spray a penetrating oil down the vacuum line to the ISV. My question is which vacuum line do I spray into? The previous posts describing this technique were not completely clear to me. Does anyone have a picture- I'm more of a visual person. Thanks for any help.
1 Post
I too,have this issue with an 86.5 car...I have found though, that the WD-40 "fix" is soooo temporary, it isn't even worth doing. EXCEPT...to verify that the IAC unit IS the culprit, and you most likely ought to get a new one as a "long-term" solution to the problem. At least thats the way I see it, after numerous "hose removal...spray...reclamp...startup, and Eureka !! moments". The short term gratification, leads to long term dismay, when you realize that the quick fix, is only a cue card to the obvious. YMMV.
Oh...and BTW, the hose you spray the WD-40 into , is the large hose connected to the rear fitting on the paasenger side valve cover. This hose runs up and under the intake to the IAC motor.
Hi 'mat
I have an 86.5 myself & you described the problem I used to have perfectly.
As you said, it ran rough for 5-10 seconds & then recovered. But if you try to drive away immediately it stumbled like a carbureted car with a bad accelerator pump. If you double pump the throttle it would scream off. That made me think I had a bad TPS. (the double pump reaction) But I had a gut feeling it was a beat MAF. After reading a few posts from John Speake about MAF theory, I bought one of John's MAF's from 928 Intl. & now I'm happier than a fa--ot in Boy's Town! It chirps the tires when it shifts like it did years ago. John is good people. That's my story & I'm stickin' to it! (BTW, I had replaced my idle air stabilizer motor & there was no change)
Thanks John
P.S. Hey John, I think this would make a great tv commercial!
Thanks John
