Just wondering? (about eBay 928)
How can you drive a 928 without a battery?
http://cgi.ebay.com/ebaymotors/Porsc...84851558QQrdZ1
Inquiring minds want to know.
Rod
Rod
Gluteus Maximus
You don't need the battery once the car is started - the alternator makes all the juice needed. However the battery provides a fair amount of voltage control so it's not a good idea as you may fry your electronics.
Rod
"ALSO SOMETIME IN THE PAST SOMEONE INSTALLED A BATTERY CUTOFF SWITCH IN THE BACK BUMPER. (THIS IS WHY I THINK THERE IS A DRAIN AND NOT THAT IT HAS A BAD BATTERY)
UNDER THE DASH THERE IS A SECONDARY STARTER BUTTON. APPARENTLY SOMETIMES THE CAR WILL NOT START BY THE KEY, SO YOU HAVE TO TURN THE KEY TO THE "RUN" POSITION AND PUSH THE BUTTON. "
I can only imagine the length of the to-do list that the lucky winner will have...
Chapter 1: Electrical Repairs
Chapter 2: Electrical Repairs, continued
Chapter 3: There's a Timing Belt? Oohh...
Chapter 4: Return to Electrical Repairs
Chronic Tool Dropper
It will run the car until the load changes faster than the voltage regulator can respond. This is usually a matter of a second or two. At that point, the alternator voltage exceeds the breakdown voltage of one or two or six diodes, and the alternator is history. Moral: NEVER try to run the car without a battery installed.
