928S2 RPM Limit LH Chip
Hi All,
I'm trying to locate the Rev Limit value on the LH chip (928S2 / S). This is for the 16 valve engine. Anybody know the hex address and the hex value? (6400rpm is the decimal value I believe).
Any help very gratefully received.
Regards,
Andrew
Milton Keynes, UK
'93 928GT Guards Red
Regards,
Andrew
Milton Keynes, UK
Hi Chris,
Yes, already asked me, I've never gone into this code, only the '87 and later....
Done anymore on your LH project ?
(Sorry Andrew, for grabbing your thread !)
"On the S4 it is a 16 bit hex value.: - Chris -
Actually, that is stored as two 8 bit bytes since the LH ECM uses a XK by 8 EPROM.
An assembler or a disassembler, e.g. DOS DEBUG, will display that value as HEX.
Now that is just getting picky !! Actually now my memory is coming back it is just an 8 bit number.
Not that is helps the original thread topic.
John I wish I had time to go back and play with it but sounds like you have made some great progress recently anyway.
Chris
Chris
