928 Forum 1978-1995
Sponsored by: 928 Specialists
Wider wheels
Old Oct 9, 2005 | 04:04 AM
ebs's Avatar
ebs
Default Wider wheels
I have found a pair of 9 inch rear wheels for sale, at a reasonable price. I currently have the stock wheels on my car (being '84 shark with US spec engine and 4 speed auto) which are 7 inch wheels all round. I see across several road tests that:
1) early cars had 7 inchess all round
2) S4 series had 7's in front and 8's in rear
3) GTS had 7.5s in front and 9s in rear
I know later series 944 Turbo had 7's in front and 9's in rear.
Has anyone had 7s in front and 9s in rear on a 928? Will it improve the handling much, or induce too much under-steer? All thoughts appreciated.
Old Oct 9, 2005 | 12:10 PM
Brent 89-GT's Avatar
Brent 89-GT
If they fit it shouldn't cause much if any trouble on the street. Like you mention, later 928s had staggered sizes. I would think you could run 225 section fronts and 255 section rears but suspect the main improvement would be in looks not performance.
Old Oct 9, 2005 | 06:11 PM
vanwyk4257's Avatar
vanwyk4257
I have 7" cup 1's and 9" cup rears with 225/45 and 255/40 tires respectively. I drove it yesterday down to a buddies shop and took a pretty twisty road for a short distance. I took some 30mph corners at about 60 and it felt pretty good. I dont think you'll have trouble with the car on the street, on the track you'll probably get some understeer with that setup.
Old Oct 9, 2005 | 06:47 PM
IcemanG17's Avatar
IcemanG17
It all depends on the wheels offset and bolt spacing...our lugs are 5x130mm & the offsets vary by wheel-MY
It should work unless the offsets are really off.
Old Oct 9, 2005 | 09:16 PM
vanwyk4257's Avatar
vanwyk4257
Good point, for a frame of reference my wheels (both front and rear) have 55mm offsets.
