Heater Opens on Acceleration
So I assume we're talking about a vacuum issue. The thing that baffles me is, when I accelerate, isn't there *more* vacuum, and shouldn't that *close* the heater valve?
Heinrich
Second for the blue/black one way valve off the brake booster. Mine also failed and flowed both directions. The way I understand vacuum is that at full throttle the engine produces very little vacuum & produces max vacuum at no throttle while "engine braking". At idle my car typically pulls 14inches off the blue/black valve...which is more than enough to close the heater valve!
Blue-black vacuum valve (p/n 843 820 675) I just replaced mine
before "Sharks in the Hood. $15 from 928 intern'l. Works great.
Check the 4-way connector, too (at the same location), $5
(p/n 117 078 00 45)
G'luck all.
(p/n 117 078 00 45)
G'luck all.
My guess is that you have a vacuum leak under the dash. Check out http://members.rennlist.com/pirtle/svc_act.html
Brian ... sounds like an easy fix
I'm going to check mine.
