Polishing components..
Gluteus Maximus
I've had good luck with using a muslin wheel on a variable speed drill. Keep the wheel damp, start with polishing compound and then a few rounds with Mothers polish. Doing it all by hand is too much work!
Man of many SIGs
Jewlers rouge works well with an electric buffing wheel. Its basicly the same as all these other specialty compounds but no fancy name brands and much cheaper. I will be starting a polishing project soon as I have just ordered another intake plennum and all the runners so I can do it without much downtime.
Shameful Thread Killer
Anodizing is an option. If you polish and buff, remember it will require regular work to maintain the bare metal to a gloss. Aluminum oxidizes too. I've tried various clear coats over bare metal, and none of them seal perfectly. The smallest pinhole will allow in moisture, and cause rot eventually.
Power coating appears to offer the best sealing, and visually appealing surface finish.
Doc
Doc
I got my professional buffer from caswell and use a 3M wheel called SS primarily for stainless but it works great on aluminum or whatever the spider is made of. Tremendous machine polish that looks even better in person. The buffing compounds are sloppy, inefficient and tedious.
