928 Forum 1978-1995
Sponsored by: 928 Specialists
Need help.. with Replacement Speakers
Old Sep 20, 2005 | 02:25 AM
Drifter's Avatar
Drifter
Question Need help.. with Replacement Speakers
Has anyone replaced their oem speakers with aftermarket speakers, and maintained the original look? I'm looking for the rear mid range & bass sets, but I don't want to make modifications, just simple remove & replace.
I've checked 928 International & 928 Specialist websites and no luck.
Old Sep 20, 2005 | 09:34 AM
pasa's Avatar
pasa
Hi Dave
MB Quarts make speakers which can be mated to the old rear speaker housings, this will give it a stock look plus improve the sound.
Regards Dan 1990 928GT
Old Sep 20, 2005 | 11:10 AM
WallyP's Avatar
WallyP
Rennlist Site Sponsor
This has been discussed at length on the Forum. A search will give much info - including that the large speakers in the late cars are two-Ohm units, so changing speakers means changing amps as well...
Old Sep 20, 2005 | 02:08 PM
Rich9928p's Avatar
Rich9928p
If your problem is the foam ring around the speaker most repair shops can fix that problem easily and it isn't too costly.
Old Sep 26, 2005 | 11:48 AM
Drifter's Avatar
Drifter
Unhappy
I'm not sure what the physical problem is but when I play the system load the base is distorted preatty bad.. like a crackling sound. I'm trying to figure out the problem. I'm looking at a "surround repair kit" in the event that is the problem.
http://www.partsexpress.com/pdf/catalog05/134pec05.pdf
