rear bearing
Does anyone have the # for the rear wheel bearing? Not the Porsche #, but a # I can take to Pervis Bearing and get a replacement. Or should I stay with the OEM bearing? Thanks
Hi Brad,
On the Bearing inner race
SKF
BAHB 636161C
and written opposite is
ITALY A M02Y
The box it came in is labelled
RUVILLE
6704 Wheel bearing kit
and on a sticker on the box (but I suspect this maybe the stockist in the UK's own stock number
628 33 0100
11233EP
Hope this helps
I'ld just try the big three unless you have an inside deal with SKF.
Cheers
Jon in NZ
SKF
BAHB 636161C
ITALY A M02Y
RUVILLE
628 33 0100
11233EP
Hope this helps
Cheers
Jon in NZ
