928 Forum 1978-1995
Sponsored by: 928 Specialists
Head Gasket Torque
Old Sep 14, 2005 | 07:17 PM
mulik51's Avatar
mulik51
Question Head Gasket Torque
Hey. I probably anooyed most of people in this forums with my questions, so I will cut to the subject.
I have heads from M28/03 engine being installed on the M28/19 block. In the WSm it says to torques the heads in 3 steps:14fp, 31fp, 61fp. But in the same table it says that fo later engines(later then M28/18) you need to torques the head as: 14.5fp, 31.5fp, 64.5fp.
So, which one do I use?
Thanks,
Klim
P.S. Yeah and the problem also lies in that torques wrench doesn't lock on halfs, it only locks in whole numbers. And I searched most of the shops around here and this one supposed to be the most accurate one. How important are .5 of foot pund?
Old Sep 14, 2005 | 07:20 PM
UKKid35's Avatar
UKKid35
Is the difference significant? In the grand scheme of things - probably not.
Old Sep 14, 2005 | 08:05 PM
GlenL's Avatar
GlenL
Round it up or down, Half a foot pound doesn't matter.
The torque method is also tied to the gasket material. Some people swear by one or the other. I like straight torques as I re-torue the heads several times and using torque values makes that easy. That is, every 12 to 24 hours back the nut off 1/8 turn and then re-click. It'll be a bit tighter each time.
You might search on this as it is debated every couple of months.
Old Sep 14, 2005 | 10:21 PM
mulik51's Avatar
mulik51
Cool. Thanks for the answer. But what torque use for the last step: 61fp or 64fp?
Thanks,
Klim
Old Sep 14, 2005 | 10:34 PM
GlenL's Avatar
GlenL
85Nm which is 62.7ft-lbs so I'd go 63.
Old Sep 15, 2005 | 12:11 AM
mulik51's Avatar
mulik51
Thanks, I will do 63fp then.
Klim
