928 Forum 1978-1995
Sponsored by: 928 Specialists
Understeer GONE!!!
Old Sep 8, 2005 | 11:26 PM
ErnestSw's Avatar
ErnestSw
There's nothing on their web site.
Old Sep 8, 2005 | 11:27 PM
justin's Avatar
justin
My opinion based on looks alone, 195mm ride height is funny looking.
Looks like a truck, the 195mm r/h is great for a stock suspension, not eibach/bilstein setup.
Originally Posted by Fogey1
Well, 195mm is the stock ride height. Maybe Porsche had some idea what it was doing.
Old Sep 8, 2005 | 11:29 PM
justin's Avatar
justin
I might cruise out there Sat. afternoon, and check it out. Only about 20 minutes from me.
Originally Posted by DG84S
Ernest,
Your mention of taking your GT to the track jogged my memory. This morning I drove through Cresson on Hwy 377 and noticed the Texas Motorsport Ranch is adding lots of new track with lots of twisties. Has anyone heard anything specific about their expansion?
Dave
Old Sep 9, 2005 | 12:00 AM
worf928's Avatar
worf928
Factory spec is 170mm to 190mm for a new 928. With 160mm acceptable for 'used' vehicles. At least that's the spec for '81 through '95 according to the spec books.
Old Sep 9, 2005 | 10:40 AM
Fogey1's Avatar
Fogey1
Originally Posted by worf928
"Factory spec is 170mm to 190mm for a new 928. With 160mm acceptable for 'used' vehicles. At least that's the spec for '81 through '95 according to the spec books."
Oops, DOH!
Tech Specs Booklet 85-89, page72:
"Front Axle height Setting 190 -20mm**"
"Rear Axle Height Setting 173 +10mm**"
"** The height setting values apply to new vehicles. Used vehicles may be up to 10 mm lower, i.e. the tolerance may deviate by minus 10mm. This must, however, be the same for both axles."
Old Sep 9, 2005 | 11:24 AM
m21sniper's Avatar
m21sniper
The new shocks springs will be very stiff, and you may find that you have rubbing once they fully settle(which took about 150 miles for my Bilstiens i just installed).
Once mine settled i realized i was getting a wee bit of rear tire/fender rub.
Old Sep 9, 2005 | 11:52 AM
ErnestSw's Avatar
ErnestSw
I'm thinking that might happen in front. The rear fenders have been flared so I THINK they'll be ok. I'm just surprised that this configuration works at all.
