Headliner Removal, Sunroof S4
Have removed the obvious screws, sunvisors etc. Still attached around the opening. What else has to be removed. Please tell me it's easy.
The rails on which the roof slides must be removed as well as front and rear bits and pieces that the headliner material is tucked under... not what you wanted to hear.
Its a real PIA for sure, to make matters worse the headliner is also glued under the rails. It takes great care to get that leather sunroof surround off in one piece.
Chris
Chris
